every trap is the same
  • seba
    • Jul 2009
    • 9
    I`ve some porblems with configuring snmptrap.pl script. Problem is every trap received by zabbix has the same value. Here`s my example of snmptrapd.log:
    2009-07-29 11:29:16 10.10.10.1 [UDP: [*.*.*.*]:53683->[*.*.*.*]]:
    DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (154984089) 17 days, 22:30:40.89	SNMPv2-MIB::snmpTrapOID.0 = OID: SNMPv2-SMI::mib-2.17.0.2	SNMPv2-SMI::enterprises.9.9.46.1.3.1.1.1.1.10 = INTEGER: 10	IF-MIB::ifName.10102 = STRING: Gi0/2
    2009-07-29 11:29:17 10.10.10.1 [UDP: [*.*.*.*]:53683->[*.*.*.*]]:
    DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (154984189) 17 days, 22:30:41.89	SNMPv2-MIB::snmpTrapOID.0 = OID: IF-MIB::linkDown	IF-MIB::ifIndex.10102 = INTEGER: 10102	IF-MIB::ifDescr.10102 = STRING: GigabitEthernet0/2	IF-MIB::ifType.10102 = INTEGER: ethernetCsmacd(6)	SNMPv2-SMI::enterprises.9.2.2.1.1.20.10102 = STRING: "down"
    2009-07-29 11:29:18 10.10.10.1 [UDP: [*.*.*.*]:53683->[*.*.*.*]]:
    DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (154984289) 17 days, 22:30:42.89	SNMPv2-MIB::snmpTrapOID.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1	SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.3753 = STRING: "LINK"	SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.3753 = INTEGER: 4	SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.3753 = STRING: "UPDOWN"	SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.3753 = STRING: "Interface GigabitEthernet0/2, changed state to down"	SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.3753 = Timeticks: (154984289) 17 days, 22:30:42.89
    and seems like everythink is ok, but here is what i get in zabbix frontend. It`s something like this:
    (*.*.*.*, *.*.*.*) DISMAN-EVENT-MIB::sysUpTimeInstance: 17:22:07:48.51
    (*.*.*.*, *.*.*.*) DISMAN-EVENT-MIB::sysUpTimeInstance: 17:22:07:21.50
    (*.*.*.*, *.*.*.*) DISMAN-EVENT-MIB::sysUpTimeInstance: 17:22:07:20.50
    and I want to get specific info (i.e. about interfaces, etc), not only uptime (from switch in this case)
    I`m sure it`s problem with snmptrap.pl script. All I want is to know which section of snmptrap.pl script edit do make it sending me all data I want.
