so i installed zabbix on a low powered board. This will be running a zabbix proxy.
Installation and configuration went fine. Proxy reports back to server perfectly.
The only trouble I'm having now is that some pings are being reported falsely. Certain devices return 0 when ping'ed, but I know those devices are up. The devices come back up in 10 minutes, and then go back down. This keeps happening all day.
I was assuming the board didnt have enough juice, but using the "top" command (its ubuntu) zabbix proxy is using no more than 5% of cpu and 1 % of memory. ntop reports network usage as normal as well. its flash memory so I'm certain its not read/write speeds that are causing the problem.
Its "wrong" ping responses more than "missing" ping responses. i.e. devices are reported as down.
From the config file, I changed forked instances to minimums (i.e. 1) but still no luck. Increased timeout to 15 seconds. still no go.
Any ideas? has anyone experienced this before ?
thanks guys !
thanks guys !
