Compile agent with different config path
  • Tenchi
    • Aug 2009
    How can I compile the agent to look for the zabbix_agentd.conf at a path different then /etc/zabbix/zabbix_agentd.conf ?
    I tried :
    --prefix=/etc/oph --exec-prefix=/etc/oph --bindir=/etc/oph --sbindir=/etc/oph --libexecdir=/etc/oph --sysconfdir=/etc/oph --datadir=/etc/oph --enable-static --enable-agent
    so it would put all files into /etc/oph but that didn'y work.
  • Tenchi
    • Aug 2009
    Also, howto change the user it runs as ?
    • Tenchi
      • Aug 2009
      I was able to find that editing zabbix_agentd.c in /src/ folder, on line 53:
      static char DEFAULT_CONFIG_FILE[] =
      can be changed to the path I wanted, however I am still unable to discern howto change what user the zabbix agent runs as.
      • Calimero
        • Nov 2006
        • 481
        --- src/libs/zbxnix/daemon.c    2009-04-03 16:44:05.000000000 +0200
        +++ src/libs/zbxnix/daemon.c.new        2009-06-12 13:27:41.626634000 +0200
        @@ -90,7 +90,7 @@
                pid_t                   pid;
                struct passwd           *pwd;
                struct sigaction        phan;
        -       char                    user[7] = "zabbix";
        +       char                    user[9] = "zabagent";
                /* running as root ?*/
                if((0 == allow_root) && (0 == getuid() || 0 == getgid()))
        For example ...
        • Tenchi
          • Aug 2009
          Thank you, that worked perfectly.
          • NOB
            • Mar 2007
            • 469
            Perfect.
            Do you want to change the source code every time a new ZABBIX version
            comes up ?
            We don't and don't have time for that.
            If you really want to start the ZABBIX agent under a different user,
            just modify the startup script to use this different user.
            That's it.
            You don't have to modify the sources for every version.
            The same is true for the configuration file.
            Just specify it on the commandline in your startup script.
            Just some hints
            Regards
            Norbert.
            • Tenchi
              • Aug 2009
              That sounds good, but what are the command line options to set that ? I did not see it in ./configure --help
              • Calimero
                • Nov 2006
                • 481
                Modify the startup script (init.d/zabbix_agentd) to setuid() before zabbix is acutally started.
                If you're on debian (and derivatives like ubuntu) you can use start-stop-daemon.
                If you're one RHEL/CentOS, theres the daemon function in /etc/init.d/functions
