I am trying to enable a disabled item under Template_Linux.
I disabled several unused items and now it turns out I need to re-enable the proc_num[zabbix_server] item
When I go into items and select template_linux it only shows me enabled items.
When I go to advanced Filter and search for status disabled I see NO items.
When I try to manually add the item I'm told it already exists.
I'm running Zabbix 1.6.3. in a distributed node layout. I disabled the item on the subnode and need to monitor the master node zabbix server host from the sub node. Master's linux template has the proper item but because I need to monitor from the sub node the sub node's linux template needs the item. Just need a way to re enable it. How would I go about this?
Any help would be appreciated.
-Chris
-Chris
