SQL query - Trends
  • bobrivers
    • Feb 2007
    • 115
    SQL query - Trends
    I'm trying to build a sql query to calculate hard disk space consumption. I thought that I could search the "trends" table and search for the data that I want.
    I was planning to get the oldest data for a specific item, then the newest data to this same item. Through the difference between this two values divided by the time gap (in days), I could determine the amount of space consumed.
    But the problem is that the table trends doesn't have any data to the itemid that I need...
    First I searched the hosts table and identified the hostid. Then I searched the items table and discovered the itemid.
    Finally I'm searching the trends table with: SELECT * FROM trends t where t.itemid = 23944; (this item represents vfs.fs.size[c:,free])
    Any advice? I thought that every monitored item should have data in trends table.
    Thanks,
    Bob.
    Obs.: Just to share something: the following sql query displays a table with the available disk drive spaces in all monitored servers (windows).
    PHP Code:
    SELECT h.host, MAX(IF(i.key_='vfs.fs.size[c:,pfree]', i.lastvalue, '')) AS 'c:',
    MAX(IF(i.key_='vfs.fs.size[d:,pfree]', i.lastvalue, '')) AS 'd:',
    MAX(IF(i.key_='vfs.fs.size[e:,pfree]', i.lastvalue, '')) AS 'e:'
    FROM `hosts` h, hosts_groups hg, items i
    WHERE h
    .hostid = hg.hostid AND h.hostid = i.hostid
    AND hg.groupid = 3 AND i.key_ LIKE '%pfree%'
    GROUP BY h.host
  • prashants
    • Dec 2008
    Have you searched in "trends_uint" table?
    -Prashant
    • bobrivers
      • Feb 2007
      • 115
      I really forgot to look into this table... Yes, the data that I need is there. As soon as I develop the query I'll share it.
