Active checks - agent send information every minute
  • felipeneuwald
    • Aug 2009
    I have these situation: Agent is not reachable from the zabbix server, but the agent can reach the zabbix server. I have configured my agent and my zabbix server like http://www.zabbix.com/wiki/doku.php?id=howto:activehost .
    As I can see, sometimes the zabbix agentd let more than 10 minutes to send informations to zabbix server. How to configure zabbix agentd to send informations to zabbix server every minute?
    Thanks, Felipe.
  • felipeneuwald
    • Aug 2009
    Update
    Just an update... take a look at queue.
    • Calimero
      • Nov 2006
      • 481
      Err... set update interval to 60sec when creating items ?
      By the way do you have enough trappers started (StartTrappers=10 in zabbix_server.conf for example) ?
      • felipeneuwald
        • Aug 2009
        I have some items that the update interval is 5 secons.
        Here is my zabbix_server.conf:
        # This is config file for ZABBIX server process
        # To get more information about ZABBIX,
        # go http://www.zabbix.com
        # This defines unique NodeID in distributed setup,
        # Default value 0 (standalone server)
        # This parameter must be between 0 and 999
        #NodeID=0
        # Number of pre-forked instances of pollers
        # Default value is 5
        # This parameter must be between 0 and 255
        #StartPollers=5
        # Number of pre-forked instances of pollers for unreachable hosts
        # Default value is 1
        #StartPollersUnreachable=1
        # Number of pre-forked instances of trappers
        StartTrappers=25
        # Number of pre-forked instances of ICMP pingers
        #StartPingers=1
        # Number of pre-forked instances of discoverers
        #StartDiscoverers=1
        # Number of pre-forked instances of HTTP pollers
        #StartHTTPPollers=1
        # Listen port for trapper. Default port number is 10051. This parameter
        # must be between 1024 and 32767
        #ListenPort=10051
        # Listen interface for trapper. Trapper will listen all network interfaces
        # if this parameter is missing.
        #ListenIP=127.0.0.1
        # How often ZABBIX will perform housekeeping procedure
        # (in hours)
        # Default value is 1 hour
        # Housekeeping is removing unnecessary information from
        # tables history, alert, and alarms
        # This parameter must be between 1 and 24
        #HousekeepingFrequency=1
        # How often ZABBIX will try to send unsent alerts
        # (in seconds)
        # Default value is 30 seconds
        SenderFrequency=30
        # Uncomment this line to disable housekeeping procedure
        #DisableHousekeeping=1
        # Specifies debug level
        # 0 - debug is not created
        # 1 - critical information
        # 2 - error information
        # 3 - warnings (default)
        # 4 - for debugging (produces lots of information)
        DebugLevel=3
        # Specifies how long we wait for agent response (in sec)
        # Must be between 1 and 30
        Timeout=10
        # Specifies how many seconds trapper may spend processing new data
        TrapperTimeout=10
        # After how many seconds of unreachability treat a host as unavailable
        #UnreachablePeriod=45
        # How ofter check host for availability during the unreachability period
        #UnavailableDelay=15
        # How ofter check host for availability during the unavailability period
        #UnavailableDelay=60
        # Name of PID file
        PidFile=/var/run/zabbix-server/zabbix_server.pid
        # Name of log file
        # If not set, syslog is used
        LogFile=/var/log/zabbix-server/zabbix_server.log
        # Maximum size of log file in MB. Set to 0 to disable automatic log rotation.
        #LogFileSize=1
        # Location for custom alert scripts
        AlertScriptsPath=/etc/zabbix/alert.d/
        # Location of 'fping. Default is /usr/sbin/fping
        # Make sure that fping binary has root permissions and SUID flag set
        #FpingLocation=/usr/sbin/fping
        # Frequency of ICMP pings (item keys 'icmpping' and 'icmppingsec'). Defauls is 6        0 seconds.
        #PingerFrequency=60
        # Database host name
        # Default is localhost
        DBHost=localhost
        # Database name
        # SQLite3 note: path to database file must be provided. DBUser and DBPassword ar        e ignored.
        DBName=zabbix
        # Database user
        DBUser=zabbix
        # Database password
        # Comment this line if no password used
        DBPassword=xxxxxxxxxx
        # Connect to MySQL using Unix socket?
        #DBSocket=/tmp/mysql.sock
