hello everybody
i am new to zabbix and i have been playing with triggers and actions for sometime.
I will explain the problem I am facing in detail
I have been monitoring a certain process on the servers using zabbix and in case the process is down i have an alert-trigger_action to re-initialise the process automatically. Although ususally reinitialization works but sometimes we have to re-install the application (e.g. HP enterprise discovery )
Can i configure zabbix master to send heavy files (.tar , .zip) to the nodes and perform a installation as an action and delete the .tar file??
thanks
thanks
