95 percentile traffic usage trigger
  • chrigu
    • Aug 2009
    Hi
    Is there a way to create a trigger that fires after a specific item (network traffic usage) has overrun 95% of the allowed values after one month?
    Background:
    I monitor and graph various switch ports via SNMP. The 95% line works fine within the graph. It would be very helpful if Zabbix will fire up a trigger for every switch port that has violated the 95% rule after one month.
    Thanks for any help.
    Chris
  • cowmix
    • Jul 2010
    I would like to know this too.
    bump!
    • troffasky
      • Jul 2008
      • 639
      How about using the "Sum of values for period of time T > N" function in the trigger?
      'T' is one month
      'N' is the figure you trigger on.
