Integer [0] not suitable for Integer?
  • Justleen
    • Jan 2009
    • 20
    Hi All,
    I just wanted to create a quick external check, when i ran into the following error in Zabbix: Type of received value [0] is not suitable for value type [Numeric (integer 64bit)]
    This is quite weird i'd say, since its a perfectly valid value? Changing to float does the same thing. I can only save it as text, which is not what I want...
    How can I get an item to accept a numerical value as value??
    The script:
    zabbix@s2m-mon-002:~/externalscripts$ ./check_mis.sh prd-as-012 QueueSize
    30
    The item:
    Type: external check
    Key: check_mis.sh[QueueSize]
    Type of info: numerical
    Dont use multiplier, and store value as is..
    Edit: THe same happens for "real" values, like, 14 or 22 ..
  • Justleen
    • Jan 2009
    • 20
    Ok, It seems that if i choose "Character" as type, I can do numerical tests ... Not sure if this is supposed to work like this, but as a work around, it works for me. THough this way I cant create graphs...
    • Justleen
      • Jan 2009
      • 20
      It seems only the numerical are usefull in triggers, so I really would like to know how to get the values from an external script accepted as a numerical value...
      Any one??
      • Calimero
        • Nov 2006
        • 481
        Sounds weird !
        What if you try:
        ./externascript.sh params... | cat -e
        to see whether output is "clean".
