I've got a SQL query that shows all the failed orders in our system. It's bounded in a Python scriptlet that returns the value to Zabbix.
I'm trying to figure out the best pattern for representing the events and alerting for them.
I could have the query show all the failed orders, but that means a) a long SQL query that has to scan all the orders, and b) variability in that value when we purge data out of the table.
Because of this, I was going to have the table report the trailing value of an amount of time. I couldn't figure out whether to have the sensor show every 5 minutes, and the query scan only the last hour (meaning that I can set an alert any time the count of failed orders increases, but the problem is if I get a spike, while another spike is leaving the 30 minute window, the issue may get hidden. It's similiar if I do 'the most recent 24 hours'.
What's a good way to approach this? I'd like to be able to graph the number of errors in a time period to see when they occured, as well as set alerts when the count increases.
Thanks!
Thanks1
Thanks!
Thanks1
