Zabbix Jabber notifications
  • tdomhan
    • Jul 2009
    • 24
    Hi folks,
    I compiled zabbix with Jabber support. Added a new jabber media via the web gui and added a jabber address to my media.
    According to the events zabbix is trying to send notifications via jabber. Though it fails after 2 retries. ("not sent", retries: 0)
    The log doesn't show anything.
    How could I get more information, like: why didn't it work?
  • troffasky
    • Jul 2008
    • 639
    Turn up the log level so Zabbix logs more about what it's trying/failing to do.
    • tdomhan
      • Jul 2009
      • 24
      that's kind of too much information. the log file gets overwritten every few seconds.
      • tdomhan
        • Jul 2009
        • 24
        ok I changed to log file size.
        this is what "grep JABBER logfile" says:
        19517:20090825:095004 JABBER: In send_jabber()
         19517:20090825:095004 JABBER: In connect_jabber('zabbix@jabberserver')
         19517:20090825:095004 JABBER: In on_stream()
         19517:20090825:095004 JABBER: End of on_stream()
         19517:20090825:095033 JABBER: End of connect_jabber():FAIL
         19517:20090825:095033 JABBER: End of send_jabber():FAIL
         19517:20090825:095103 JABBER: In send_jabber()
         19517:20090825:095103 JABBER: In connect_jabber('zabbix@jabberserver')
         19517:20090825:095103 JABBER: In on_stream()
         19517:20090825:095103 JABBER: End of on_stream()
         19517:20090825:095131 JABBER: End of connect_jabber():FAIL
         19517:20090825:095131 JABBER: End of send_jabber():FAIL
         19517:20090825:095201 JABBER: In send_jabber()
         19517:20090825:095201 JABBER: In connect_jabber('zabbix@jabberserver')
         19517:20090825:095201 JABBER: In on_stream()
         19517:20090825:095201 JABBER: End of on_stream()
         19517:20090825:095230 JABBER: End of connect_jabber():FAIL
         19517:20090825:095230 JABBER: End of send_jabber():FAIL
        the server is running openfire. I have no problem connection to it via spark(xmpp client).
