Solaris: Under which user will Zabbix Perform own Checks
  • DavidK
    • Jul 2009
    i've wrote an script that parses all necessary informations about different SUN Hardwareplatforms from the prtdiag command. The command is executable via sudo for the zabbix User without password. But it seems that the zabbix Agent run the Checks as a different User.
    Can anyone tell me which user runs the own checks?
    Greetings
  • richlv
    • Oct 2005
    • 3112
    the command should be run as zabbix user, at least for any reasonably recent version.
    why do you think it is run as a different user ?
    remember that zabbix agents do not preserve environment, so you would have to do that yourself.
    • DavidK
      • Jul 2009
      Hi
      sorry for the dump question, i do a zabbix check which tells me the output from "id", so i c that it runs under the zabbix user.
      So it was only a simple error in the perl code - now everything works
      thx anyway
