How to check SWITCH is alive
Here it is:
# This is config file for ZABBIX server process
# To get more information about ZABBIX,
# go http://www.zabbix.com
# This defines unique NodeID in distributed setup,
# Default value 0 (standalone server)
# This parameter must be between 0 and 999
#NodeID=0
# Number of pre-forked instances of pollers
# Default value is 5
# This parameter must be between 0 and 255
#StartPollers=5
# Number of pre-forked instances of IPMI pollers
# Default value is 0
#StartIPMIPollers=0
# Number of pre-forked instances of pollers for unreachable hosts
# Default value is 1
#StartPollersUnreachable=1
# Number of pre-forked instances of trappers
#StartTrappers=5
# Number of pre-forked instances of ICMP pingers
#StartPingers=1
# Number of pre-forked instances of discoverers
#StartDiscoverers=1
# Number of pre-forked instances of HTTP pollers
#StartHTTPPollers=1
# Listen port for trapper. Default port number is 10051. This parameter
# must be between 1024 and 32767
#ListenPort=10051
# Source IP address for outgoing connections
#SourceIP=
# Listen interface for trapper. Trapper will listen on all network interfaces
# if this parameter is missing.
#ListenIP=127.0.0.1
# How often ZABBIX will perform housekeeping procedure
# (in hours)
# Default value is 1 hour
# Housekeeping is removing unnecessary information from
# tables history, alert, and alarms
# This parameter must be between 1 and 24
#HousekeepingFrequency=1
# How often ZABBIX will try to send unsent alerts
# (in seconds)
# Default value is 30 seconds
SenderFrequency=30
# Uncomment this line to disable housekeeping procedure
#DisableHousekeeping=1
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=3
# Specifies how long we wait for agent response (in sec)
# Must be between 1 and 30
Timeout=5
# Specifies how many seconds trapper may spend processing new data
# Must be between 1 and 300
#TrapperTimeout=5
# After how many seconds of unreachability treat a host as unavailable
#UnreachablePeriod=45
# How often check host for availability during the unavailability period
#UnavailableDelay=60
# Name of PID file
PidFile=/var/run/zabbix-server/zabbix_server.pid
# Name of log file
# If not set, syslog is used
LogFile=/var/log/zabbix-server/zabbix_server.log
# Maximum size of log file in MB. Set to 0 to disable automatic log rotation.
#LogFileSize=1
# Location for custom alert scripts
AlertScriptsPath=/etc/zabbix/alert.d/
# Location of external scripts
#ExternalScripts=/etc/zabbix/externalscripts
# Location of fping. Default is /usr/sbin/fping
# Make sure that fping binary has root permissions and SUID flag set
FpingLocation=/usr/sbin/fping
# Location of fping6. Default is /usr/sbin/fping6
#Fping6Location=/usr/sbin/fping6
# Temporary directory. Default is /tmp
#TmpDir=/tmp
# Frequency of ICMP pings (item keys 'icmpping' and 'icmppingsec'). Default is 60 seconds.
#PingerFrequency=60
# Database host name
# Default is localhost
#DBHost=localhost
# Database name
# SQLite3 note: path to database file must be provided. DBUser and DBPassword are ignored.
DBName=zabbix
# Database user
DBUser=root
# Database password
# Comment this line if no password used
DBPassword=
# Connect to MySQL using Unix socket?
#DBSocket=/tmp/mysql.sockComment
Please! Anyone? Really need this working!Comment
Bump....Come on people...Comment
Same problem
I've the same problem
Have you solved this?Code:zabbix_server_32541.pinger: [13] Permission denied
I think i've the good rights ?
Code:lrwxrwxrwx 1 root root 12 mai 20 17:38 /usr/sbin/fping
Hi, yes its solved, when I reinstalled version 1.8.2 to a new server.
If you running zabbix as root, it schould do it, but if you running it as zabbix user, try to chown root:zabbixComment
Thanks for your answered
I tried it, I tried a lot of configuration .. and it doesnt work...
And I can make a fping from my server.....
fouuuu I didn't know : make a ping will be so difficult...Comment
Waww O_O !!
Thanks a lot, I just made a :
And it works.Code:chmod 777 -R /tmp
But why? what was the reason of the problam? (fping use /tmp? )Comment
