Disk / Memory USED
  • fonzisherman
    • Sep 2009
    • 11
    Disk / Memory USED
    Hi I have been searching through the forums and howtos for this, and have come up empty. I am curious how to get something like vfs.fs.size [c:,used] to work, and vm.memory.size [used]. i know there is a total and free, so if there is a way to have an item as a calculation (total - free) that would be fine, but looking at my graphs it seems counter intuitive to show free space and not used. i would basically like to graph on used space, memory, is there a way?
  • MrKen
    • Oct 2008
    • 652
    According to page 101 Zabbix manual, there is no vm.memory.size[used].
    vfs.fs.size [c:,used] works fine for me.
    Type: zabbix agent
    Key: vfs.fs.size[c:,used]
    Type of info: Numeric (unsigned)
    Units: B
    Graphs for disk space, I use Total disk space & Used disk space. You can clearly see how much space is free.
    HTH
    • fonzisherman
      • Sep 2009
      • 11
      thanks, disk space used is working. has anyone done anything to get memory used somehow? this is on a windows server.
      • fonzisherman
        • Sep 2009
        • 11
        anyone graphing on memory used somehow? seems like it would be a common way to visualize.. any help is appreciated!
        • MrKen
          • Oct 2008
          • 652
          Not as difficult as you think.
          In fact, it's the same as what I posted above for Disk Space graphs. Except this time you use
          vm.memory.size[total]
          vm.memory.size[free]
          MrKen
          • Calimero
            • Nov 2006
            • 481
            There's also vm.memory.size[available] which is memory that's free and "freeable" (free + cache + buffers) and is usually a bit more interesting than just "free".
            • fonzisherman
              • Sep 2009
              • 11
              thanks, i guess its just a little counter-intuitive to see available/free vs used. from a monitoring/alert standpoint it doesnt really matter but from a graphing perspective i think 'used' would make more sense at a glance.
              • MrKen
                • Oct 2008
                • 652
                That's very interesting. Thanks for that.
                I couldn't find it in my manual V1.6 Release 014, so I just downloaded the latest version, Release 017, and guess what? it's not there either.
                Then I came across ZBX-390 where Alexei, on 8 July, is quoted as saying, "Fixed for 1.6.x manual. The old manual for 1.4.x won't be amended."
                MrKen
                • Calimero
                  • Nov 2006
                  • 481
                  I discovered it while browsing the zabbix_agent code for a unrelated problem.
                  And as we now have 'available' and 'total' I wish there were a 'used' parameter (total - available). Probably not a big change.
                  So far we use a UserParameter (free | grep ...) to get that value. But well... the less userparameters the better.
                  • hannibal20
                    • Jan 2007
                    • 22
                    the vm.memory.size[available] item works only under linux ;-/
                    • harmonica
                      • Jan 2009
                      • 251
                      I,
                      Perhaps with one script. Something as this:
                      #!/bin/bash
                      MTOTAL=`cat /proc/meminfo | grep "MemTotal" | sed 's/MemTotal: //g' | sed 's/ kB//g'`
                      MFREE=`cat /proc/meminfo | grep "MemFree" | sed 's/MemFree: //g' | sed 's/ kB//g'`
                      Kb=1024
                      echo $(((MTOTAL-MFREE)*Kb))
                      exit
