I have 700 hosts to add to zabbix.
It is not possible to do this by IP range, as the IP ranges are not unique to these hosts. These systems are served IP addresses by DHCP, and other similar hosts will be in those ranges.
I can produce a list of DNS names of the hosts, but I need some method of automating the creation of these 700+ hosts, and applying a common template to these.
I understand we have an XML import capability. What is the format for this XML import? Is there a command line tool?
