Using SNMP check
  • manfro
    • Jun 2006
    • 25
    Using SNMP check
    Hello guys,
    it is the very first time I'm using zabbix to monitor SNMP device.
    This is what I've done:
    - creating a template with only one item:
    Type SNMP v2 agent
    OID MIB::sysObjectID.0
    SNMP Community XXXX
    etc... etc...
    - creating a host: ip x.x.x.x, port 161, not monitored, linked to the previous template
    Now:
    Item status is active and no error is reported.
    Where can I see incoming data? I can't see anything in latest value section.
    Am I wrong in using it?
    Thank you.
  • Jun.Liu
    • Apr 2007
    • 91
    hi, manfro
    Did you link your host with the template?
    • MrKen
      • Oct 2008
      • 652
      Is snmp enabled on the device you want to monitor?
      Can you snmpwalk the device from the Zabbix server?
      snmpwalk -v2c -c XXXX x.x.x.x sysObjectID
