I am new to Zabbix and have been handed the task of upgrading to v1.6.6 from 1.6.1. It is currently running on Ubuntu 9.04. I have the installation instructions however when it says it's quite simple to upgrade and to use the current installation instructions, the current installation instructions aren't as straight forward as they make it out to be. I found this statement on another post: "Just make new binaries, overwrite front-end files and restart everything. Also execute the SQL statements from the release notes"
So my question is, is how do you make and install the new binaries and front end? Many thanks. todd
One other thing on a side note, how can you tell what account Zabbix is running under. I see that there is a profile for a user called Zabbix, but when you look in the users and groups it doesn't exist. You can't make a user zabbix because it says it already exists. tb
), check out the manual - it should give basic instructions.
