single template to monitor similar filesystems
  • heliopaixao
    • Mar 2009
    Dear guys,
    we have several servers with the following filesystems:
    server1
    /commonname/ABC/dir1
    /commonname/ABC/dir2
    /commonname/ABC/dir3
    /commonname/ABC/dir4
    server2
    /commonname/FGH/dir1
    /commonname/FGH/dir2
    /commonname/FGH/dir3
    /commonname/FGH/dir4
    server3
    /commonname/XYC/dir1
    /commonname/XYC/dir2
    /commonname/XYC/dir3
    /commonname/XYC/dir4
    How can I create a single template to monitor filesystem usage of all these servers?
  • bobrivers
    • Feb 2007
    • 115
    vfs.fs.size
    Since the filesystems names change across servers, probably is better to build one template per server.
    Simple create a template and then add an item to it, like:
    PHP Code:
    vfs.fs.size[/commonname/ABC/dir1,used]
    vfs.fs.size[/commonname/ABC/dir2,used]
    vfs.fs.size[/commonname/ABC/dir3,used]
    In fact I never used it this way, I always stop at the "first level", like:
    PHP Code:
    vfs.fs.size[/home,used]
    • heliopaixao
      • Mar 2009
      filesystem levels
      in fact we got 5 filesystems at that servers:
      /commonname
      and
      /commonname/ABC/dir[1-4].
      I was wondering if there was a way to do a trigger like:
      name:
      Low free disk space on {HOSTNAME} volume /oracle/{SID}/sapdata1
      expression:
      {Template_HPUXJM:vfs.fs.size[/commonname/{SID}/sapdata1,pfree].last(0)}<10
      Helio Paixao
