trigger time()
  • thomh
    • Oct 2008
    trigger time()
    hi
    i'm hoping someone can point out where i'm going wrong with the trigger time() function.
    i'm using the folllowing expression to monitor a process called MailStats ourtside of the hours of 00:00 & 02:00 (when the process is stopped for backups):
    {myhostroc.num[,,,MailStats].last(0)}=0 & {myhostroc.num[,,,MailStats].time(0)}>020000 & {myhostroc.num[,,,MailStats].time(0)}<000000
    but the trigger keeps paging. i''ve played around with variations on the above such as:
    {myhostroc.num[,,,MailStats].last(0)}=0 & (({myhostroc.num[,,,MailStats].time(0)}>020000)|({myhostroc.num[,,,MailStats].time(0)}<000000))
    but same result - the zabbix server seems to ignore the time function. worse, it seems that outside the period defined (00:00 - 02:00) the trigger doesn't trigger anymore.
    and of course if i remove the time functions the trigger alerts fine...
    i've also tested using a basic icmpping trigger and i get the same results so it's not specific to the proc.num function
    is there something i'm missing here to get the time function to work?
    i've tested the same expression on zabbix 1.6.5 and 1.4.2 so i'm pretty sure it's something i'm doing (or not doing).
    any help much appreciated!
  • harmonica
    • Jan 2009
    • 251
    Try ({myhost: proc.num[,,,MailStats].last(0)}=0)&(({myhost: proc.num[,,,MailStats].time(0)}>020000)|({myhost: proc.num[,,,MailStats].time(0)}<000000))
    • Calimero
      • Nov 2006
      • 481
      Sound weird. We use that trigger for a web scenario monitoring one of our flash media servers that is restarted everyday around 5 o'clock.
      ({myserver:web.test.fail[FMS].min(#3)}>0)
          ({myserver:web.test.fail[FMS].time(0)}<045900)
          ({myserver:web.test.fail[FMS].time(0)}>051500)
      Or, on a single line as you would give it to zabbix:
      ({myserver:web.test.fail[FMS].min(#3)}>0)&(({myserver:web.test.fail[FMS].time(0)}<045900)|({myserver:web.test.fail[FMS].time(0)}>051500))
      • otheus
        • Mar 2009
        • 53
        Why are you testing for a time LESS than 0? Don't you want it < 23:59, or {item} < 235959 ?
        • sevan
          • Aug 2011
          • 11
          trigger timer
          Guys,
          would you please explain what this trigger mean:
