Unable to start Zabbix on FreeBSD
  • w6vms
    • Sep 2009
    Greetings,
    When I try to start zabbix_server, I get:
    51005:20090914:220613 Starting zabbix_server. ZABBIX 1.6.5 (revision 7442).
    51005:20090914:220613 **** Enabled features ****
    51005:20090914:220613 SNMP monitoring: YES
    51005:20090914:220613 WEB monitoring: YES
    51005:20090914:220613 Jabber notifications: YES
    51005:20090914:220613 ODBC: NO
    51005:20090914:220613 IPv6 support: YES
    51005:20090914:220613 **************************
    zabbix_server [51005]: php_sem_get: Can not create IPC key for path 'zabbix', try to create for path '.' [No such file or directory]
    51005:20090914:220613 [Z3001] Connection to database 'zabbix' failed: [0] unable to open database file
    Zabbix 1.6.5, FreeBSD 7.2-RELEASE, MySQL 5.0
    The zabbix database exists, so does the user/password I told zabbix to use to connect to the database and said user was granted all privileges on the zabbix database.
    Any ideas?
    Thanks!
    -jav
