ZBX_TCP_READ() failed error
  • niumar
    • Sep 2009
    • 25
    Hello List! I'm new on the list, but I already use zabbix for a long time.
    I searched in forum about problems with the error "Error while receiving answer from server [ZBX_TCP_READ() failed [Interrupted system call]]" that is showed me on the zabbix proxy clients. I found two or three treads, but no solutions. They commented about the time out of the connections. I changed it to the maximum, 30 seconds, on zabbix server and on the proxys... nothing changed.
    I have a structure with one server and a lot of remote clients where every client is formed with one proxy and three agents below it (three computers in total for one client).
    At a moment all the proxys return the error above described. When this occurs, the queue goes red for all the remote proxys (keys are delayed by over 10 minutes).
    I can't believe only on a network latency, because there are situations where the link consistence is good and the problem is still occurring. Another question... Why all the proxys are affected at the same time?
    The link technology that used for the clients is a ADSL 300 kbps, not totally granted. (Is this enough?).
    Is there a answer for this situation?
  • alessandro.silva
    • Feb 2013
    • 22
    Help me please
    Niumar,
    How do you resolved it ? I've have the same problem in my network.
    • cyber_geek5
      • Apr 2013
      • 19
      I have had the same problem , currently doing a eval of Zabbix 2.0.6 , couple of solaris nodes went through fine and i see the Green Z icon on the zabbix console against these hosts
      When i tried to add a third solaris 10 node ( zabbix agentd installed on listening on port 10050 ) i notice the Z icon against the node turned red when i bring the mouse over that i see this error
      Get value from agent failed: ZBX_TCP_READ() failed: [4] Interrupted system call
      Any known solutions that can fix these
      Cyber
