Good Morning
I was wondering if anyone knows how to open a link in a new window to a external site? i would like to create a new menu next to "Administration" then below that have links that would open our helpdesk and other stuff.
This is what i have, just wondering instead of using tools_1.php it can open a new window to a external link
frontends/php$ svn diff js include/page_header.php
Index: js/common.js
--- js/common.js (revision 16)
+++ js/common.js (working copy)
@@ -501,7 +501,7 @@
// Author: Aly
var MMenu = {
-menus: {'empty': 0, 'view': 0, 'cm': 0, 'reports': 0, 'config': 0, 'admin': 0},
+menus: {'empty': 0, 'view': 0, 'cm': 0, 'reports': 0, 'config': 0, 'admin': 0, 'tools': 0},
def_label: null,
sub_active: false,
timeout: null,
Index: include/page_header.php
--- include/page_header.php (revision 16)
+++ include/page_header.php (working copy)
@@ -255,6 +255,18 @@
'sub_pages'=>array('setup.php','warning.php'))
+ 'tools'=>array(
+ 'label' => "Tools",
+ 'user_type' => USER_TYPE_ZABBIX_USER,
+ 'node_perm' => PERM_READ_WRITE,
+ 'default_page_id' => 1,
+ 'forse_disable_subnodes'=> true,
+ 'pages'=>array(
+ array('url'=>'tools_1.php', 'label'=>'Tool #1'),
+ array('url'=>'tools_2.php', 'label'=>'Tool #2'),
+ array('url'=>'tools_3.php', 'label'=>'Tool #3'),
'login'=>array(
'label' => S_LOGIN,
'user_type' => 0,
Index: js/common.js
@@ -501,7 +501,7 @@
// Author: Aly
var MMenu = {
def_label: null,
sub_active: false,
timeout: null,
+ 'tools'=>array(
+ 'pages'=>array(
'login'=>array(
'label' => S_LOGIN,
'user_type' => 0,
