Hard disk monitoring
  • mrmurdock
    • Aug 2009
    • 85
    I can see where the built in zabbix vfs.dev.read would might work for disk0 but how to extend that variable to include 2, 4, 20, 395, etc...disks to check? Where does it get the number of disks on the system and which ar functional which are not? what factor does it use to determine disk is good or bad or marginal, or going bad? Thanks
  • nelsonab
    • Sep 2006
    • 1233
    If you are referring to checking multiple disks within one read key, it's not directly possible. You would need to write a external script that iterates through the proc directory. The use of the sum aggregation function will not work as it only works across groups of hosts with the same key.
    As for knowing when a drive is about to fail, that can be a tough one. Often folks say that if you get one sector error that means the drive is on it's way out, however with the error correction on most drives you don't know about a sector error often until late in the game. SMARTD can tell you some more information but I haven't had experience on seeing a failure.
    I don't know if I posted my SMARTD recipe to the wiki, if not I'll post it when I get a chance.
    RHCE, author of zbxapi
    • bbrendon
      • Sep 2005
      • 873
      Do you use SMART? Anyone find monitoring of SMART actually helps?
      I've done some basic poking around with it, but haven't found it of much value. I know 3ware and RAIDZ keep track of SMART for you. I don't think linux software RAID does anything SMART related.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • xaeth
        • Nov 2004
        • 67
        So one thing that we have optimized as much as possible was a basic read from /proc. On RHEL3 it was in /proc/partitions and in RHEL5 it was in /proc/diskstats (I assume that thsi one likely works w/ RHEL4 as well)
        Here is RHEL5
        # Disk I/O Stats
        UserParameter=custom.vfs.dev.read.ops[*],awk '/$1/{print $$5; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.read.sectors[*],awk '/$1/{print $$7; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.read.ms[*],awk '/$1/{print $$8; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.write.ops[*],awk '/$1/{print $$9; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.write.sectors[*],awk '/$1/{print $$11; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.write.ms[*],awk '/$1/{print $$12; exit}' /proc/partitions
        UserParameter=custom.vfs.dev.io.active[*],awk '/$1/{print $$13; exit}' /proc/partitons
        UserParameter=custom.vfs.dev.io.ms[*],awk '/$1/{print $$14; exit}' /proc/partitions
        Here is RHEL5
        # Disk I/O Stats
        UserParameter=custom.vfs.dev.read.ops[*],awk '/$1/{print $$4; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.read.sectors[*],awk '/$1/{print $$6; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.read.ms[*],awk '/$1/{print $$7; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.write.ops[*],awk '/$1/{print $$8; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.write.sectors[*],awk '/$1/{print $$10; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.write.ms[*],awk '/$1/{print $$11; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.io.active[*],awk '/$1/{print $$12; exit}' /proc/diskstats
        UserParameter=custom.vfs.dev.io.ms[*],awk '/$1/{print $$13; exit}' /proc/diskstats
        And when you make the items in the web front end I believe you must set "Store Value" to "Delta (speed per second)"
        • NOB
          • Mar 2007
          • 469
          Hi brendon
          I poked around with it on Solaris 9.
          The problem is: the smarttools are not useable if you use disk mirroring (in SW).
          Reason: the virtual disk does not support SMART (it is a SW disk, finally)
          and there is no access to the connected hard disks: Drive busy !
          So we use "iostat" on Solaris, now, for disk monitoring.
          It'll allow predictive monitoring, etc.
          A simple user parameter and you're done.
          Regards
          Norbert.
          • cviniciusm
            • Sep 2009
            How to use it on Zabbix front-end?
            Could you show an example of how to use it in the Zabbix front-end, please?
            Thanks in advance.
