node disappears
  • stage
    • Sep 2009
    • 34
    node disappears
    When I create a new node in the GUI I can see and interact with it (so far so good)
    But when I leaf it alone for a while the node disappears out of my GUI.
    I can recreate it with the same parameters and then I can interact with it aging as before.
    What can I do so that de node doesn’t disappears
    I’m using zabbix 1.6.6 and the communication between the two nodes go’s as expected.
  • bobrivers
    • Feb 2007
    • 115
    probably template/host group
    one time it happened to me and it was because I didn't associated it with a template/host group
    • stage
      • Sep 2009
      • 34
      not what i mean
      I’m sorry but that’s not what I mean.
      I mean the child zabbix server disappears out of my master zabbix server config.
      Every time I need to recreate the child (node) zabbix server in my master zabbix server.
      It disappears in about 5 – 10 minutes after creation.
      • stage
        • Sep 2009
        • 34
        change your node naming
        This is my finding don't call your node "testx" (where x is a number) in the master node.
        I have changed it to "eenNaam" and it stays fine.
