Host side ping
  • coop
    • Aug 2009
    • 46
    Host side ping
    I'm working on a new Zabbix implementation (switching over from Nagios) and I've been asked to setup a host side ping on a Windows system. They need a ping type request to originate from the host and report back it's results in something Zabbix can handle.
    Has anyone tinkered with this? I can launch a UserParameter with a ping command and get data back, but shaping that into something Zabbix can show as Ok or Problem is where I'm stuck.... I just get the ping response lines.
    Thanks!
  • Calimero
    • Nov 2006
    • 481
    You need to create a trigger.
    Config > Triggers. Choose host, click Create Trigger.
    Expression: click Insert to open the selection/wizard pop-up.
    Choose your host, choose your 'ping' item. Function: choose 'Last value = N', Set N to 0. Click Insert.
    Expression will look like:
    {your_hostname:your_ping_item.last(0)}=0
    ==> Trigger will be ON (problem) when last value is 0
    Define trigger severity. Click Save.
    • coop
      • Aug 2009
      • 46
      Thanks for the reply!!
      The trigger setup looks great, but I'm not sure I see how that will force my Ping check to come from the agent system instead of the Zabbix server. I need to see the results of the agent system pinging a device.
      Sorry, I should have worded my question properly.
      • coop
        • Aug 2009
        • 46
        I think we may have resolved this. This is one method, but if someone else has a better method that would be great.
        (1) Setup a User Parameter in the zabbix_agentd.conf file:
        UserParameter=local.ping[*],C:\temp\localping.bat $1
        (2) Create a file called localping.bat with the following lines:
        @echo off
        PING %1 -n 1 | FIND "TTL=" >NUL
        IF NOT ERRORLEVEL 1 GOTO ONLINE
        IF ERRORLEVEL 1 GOTO OFFLINE
        GOTO END
        :OFFLINE
        ECHO 0
        GOTO END
        :ONLINE
        ECHO 1
        GOTO END
        :END
        (3) Create Item for host with the key local.ping[host-to-ping]
        I also set my Show Value to Service Map.
        Restart the agent and away it goes.
        • easy_john
          • Jan 2008
          • 28
          One line to zabbix_agentd.conf
          # local.ping
          UserParameter=local.ping[*],ping $1 -n 1 |find "TTL=">NUL && echo 1 || echo 0
