Imporating large ammount of Host
  • tid008
    • Mar 2009
    Hello ,
    I'am actually trying to import large amount of host into my zabbix serveur ( V1.4)
    The xml allow to attribute Host group , but no template.
    The attribution of template can be done by the auto-discovery, but i am note really confident in this.
    Is there a way to attribute template efficently without the web interface, or by attribuying template to an entire HostGroup.
    Thanks for your Help.
    I can't wait for the 1.8 !
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Yes, you could specify template linkage in the XML file. It is supported in 1.6.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
