I am not proficient with Linux, so it makes the Zabbix installer guide tough to follow. I want to test this application against Nagios (which was easy to install); I suspect Zabbix is more in line with our needs -- which is why I am eager to get it running. My test OS is the latest version of Ubuntu Desktop. I think after my initial questions are answered, I can follow the rest of the installation guide.
Questions:
1. Under software requirements, several database types are listed. Which one is the better choice?
2. The remaining requirements in section 2.4.1 are confusing:
Where do I get these files, choose the right version and install them? Same goes for the database? I went to MySQL and got lost in their lengthy list of choices.
What would help is someone <in simple terms> help me get through section 2.4.1 procedurally so I can begin installing Zabbix.
Thanks in advance,
Jeff
Questions:
- Net-SNMP
- Iksemel Library and header files
- Libcurl library and header files
- C Compiler
- GNU Make
Thanks in advance,
Jeff
