Zabbix Agent Binary for Linux x64 (Openfiler 2.3)
  • jsidhu
    • Oct 2009
    Hey guys,
    Can someone help me track down a binary for my OpenFiler box? It doesn't come with any development tools so i can't compile one. None of the systems I have are similar so the binaries that i've got will not run on this machine.
    I've not had any luck in getting one from the Openfiler community.
    Linux Filer-1 2.6.26.8-1.0.11.smp.gcc3.4.x86_64 #1 SMP Sun Jan 11 02:42:55 GMT 2009 x86_64 x86_64 x86_64 GNU/Linux
    Thanks,
    js
  • ljohnson
    • Oct 2013
    How to install zabbix agent on openfiler
    I had encountered the same obstacle.
    I was able to install the agent after a bit of research.
    I posted the steps I followed here:
    I hope this helps.
    If it does, please let me know...thanks!
    • steveboyson
      • Jul 2013
      • 582
      Seems to be an old post, but Aunty Google knows something.
      openfiler.com is your first and best source for information about openfiler. Here you will also find topics relating to issues of general interest. We hope you find what you are looking for!
      • ljohnson
        • Oct 2013
        yea, but...
        i saw the same when i was googling around, and found that the link to the binary was stale. so i had to rebuild it and thought i might share the steps since those did not seem so easy to find.
        • zalex_ua
          • Oct 2009
          • 1286
          Just FYI - https://support.zabbix.com/browse/ZBXNEXT-795
