Compiling zabbix-1.1beta1 on a SuSE 9.3
  • nascimento.rp
    • Sep 2005
    Hi ALL,
    I'm trying to compiling zabbix-1.1beta1 on a SuSE 9.3, I made this steps:
    # tar -xzvf zabbix-1.1beta1.tar.gz [This step OK]
    # cd zabbix-1.1beta1 [This step OK]
    # ./configure --with-mysql [This step OK]
    # make [This step failed ]
    Making all in src
    make[1]: Entering directory `/programas/inst.zabbix/zabbix-1.1beta1/src'
    make[2]: Entering directory `/programas/inst.zabbix/zabbix-1.1beta1/src'
    make[2]: Nothing to be done for `all-am'.
    make[2]: Leaving directory `/programas/inst.zabbix/zabbix-1.1beta1/src'
    make[1]: Leaving directory `/programas/inst.zabbix/zabbix-1.1beta1/src'
    make[1]: Entering directory `/programas/inst.zabbix/zabbix-1.1beta1'
    make[1]: Nothing to be done for `all-am'.
    make[1]: Leaving directory `/programas/inst.zabbix/zabbix-1.1beta1'
    What's happen?
    Thanks and regards,
    Nascimento
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    As of 1.1alpha12, you need to tell configure what you wish to build with;
    --with-server To tell it to build the server piece.
    --with-agent To tell it to build the agent piece.
    Without those it will assume that you are simply building the UI and basically do nothing.
    Unofficial Zabbix Developer
    • nascimento.rp
      • Sep 2005
      Ok!
      JW,
      Thanks! Can you tell me if exists a documentation about this version?
      Thanks and regards,
      Nascimento
      • nascimento.rp
        • Sep 2005
        The problem persists.
        JW,
        The problem with MAKE persists. I made the step # ./configure --with-mysql --server and after it I ran the # make and got the same problem.
        thanks,
        Nascimento
        • James Wells
          • Jun 2005
          • 664
          JW,
          thanks,
          Nascimento
          My bad, is supposed to be --enable-server and / or --enable-agent
          • elkor
            • Jul 2005
            • 299
            A good rule of thumb, whenever compiling a new package, is first to run ./configure --help.
            This will usually tell you what flags are permissable and may even show you things that can be built in but are not in the docs or README files.
