Logfile Monitoring & Trigger Comments
  • mbrand5371
    • May 2009
    • 55
    I've configured the following Item:
    Description		LSKN_Values_/var/log/lskn/lskn_procmon.log
    Type			ZABBIX agent (active)
    Key			log[/var/log/lskn/lskn_procmon.log]
    Type of information	Log
    And Trigger:
    Name		LSKN_Values_/var/log/lskn/lskn_procmon.log_ALERT
    Expression	{LSKN_Template_procmon:log[/var/log/lskn/lskn_procmon.log].str(alert)}=1
    The logfile entry looks like:
    Wed Oct 28 11:40:05 CET 2009 alert: Prozess: /usr/sbin/sshd der Applikation: sshd-Daemon gestoert. Bitte folgendes Team benachrichtigen: LSKN-Unix-Nivadis
    I try give me an event, if the word "alert" is found in the logfile but it does'nt work.
    BTW: Is ist posible to get an Trigger "comment" which contains the full logfile entry ?
    Regards, Marcus
  • richlv
    • Oct 2005
    • 3112
    is the data coming in that item actually ?
    • mbrand5371
      • May 2009
      • 55
      We've found the mistake.
      Our Zabbix reference Server and Zabbix agentd are running on one system.
      In zabbix-agendt.conf we configured the service-ip as zabbix-server.
      After setting "localhost" as server active checks would be deployed an performed.
      Setting other systems to service-ip will work too
