How to check for time drift?
  • Crazy Marty
    • Sep 2007
    • 75
    I'd like to create a trigger (in Zabbix 1.6.1) that compares a "sacred machine"'s localtime to another monitored machine's localtime. If I create a trigger like:
    ({T_Linux_time:system.localtime.last(0)}-{Timehost:system.localtime.last(0)})>3600
    in template "T_Linux_time", Zabbix complains that I can't mix template hosts (I think it means templates *and* hosts).
    I just want to make sure none of the monitored machines drift too far.... I can't rely on having ntp running on them all, because they're not all physical machines (ntp does not play well on Xen or VMware virtual machines).
    Any ideas?
  • richlv
    • Oct 2005
    • 3112
    you can check localtime against zabbix server time (i think fuzzytime function).
    so if you have ntpd on zabbix server, that should work nicely.
    • tzn
      • Apr 2011
      • 19
      Would you elaborate on that?
      • simonseztech
        • Dec 2011
        Check if client local time is in sync with Zabbix server time
        Use of function fuzzytime():
        {MySQL_DB:system.localtime.fuzzytime(10)}=0
        The trigger will change to the problem state in case when local time on server MySQL_DB and Zabbix server differs by more than 10 seconds.
        • tzn
          • Apr 2011
          • 19
          Thanks! Ones has only to take care of time on Zabbix server
