system.cpu.util
  • julien56
    • Nov 2009
    system.cpu.util
    Hi all,
    On my zabbix server 1.6.6, i want to monitor and make an alert when the windows server processor exceed 80 %.
    My items CI is : system.cpu.util[avg1]
    My Triggers is : {hostname:system.cpu.util[avg1].last(0)}>80
    There are no problems for zabbix when i validate but i haven't a warning when the processor of my windows server exceed 80 %(I do this with cpu burner).
    Of course the agent on the windows server is ok. Agent 1.6.6.
    My triggers is wrong ?
    Thank you.
  • stage
    • Sep 2009
    • 34
    Try this
    {hostname:system.cpu.util[]last(0)}>80
    It works for me.
    • julien56
      • Nov 2009
      humm okay but...
      for me the command is
      my triggers : {hostname:system.cpu.util[].last(0)}>80
      have you forgot the "." before last(0)}>80 in your command ?
      thank you for your help.
      • stage
        • Sep 2009
        • 34
        Yes i forgot the "."
        i have :
        item: system.cpu.util[]
        trigger : {hostname:system.cpu.util[].last(0)}>80
        above gives you a alert every time it go's over the value (what gives a lot of alerts if the use is around the 80%). I promis you, you will go nuts.
        trigger: {hostname:system.cpu.util[].avg(600)}>80
        this will give u more comfort, it gives you an alert every time the averige over 600 sec go's over 80%
        • julien56
          • Nov 2009
          ok. I repeat because i haven't a good english and i want understand correctly.
          This line give an alert if the charge of processor exceed 80% during 600 seconds ?
          thank you
          • julien56
            • Nov 2009
            For me it works but i have a strange mode.
            I explain :
            With this line {hostname:system.cpu.util[].last(0)}>80 i have an alert but after 7 minutes (Items update interval for system.cpu.util is 10 second !)
            So with your Improvement trigger: {hostname:system.cpu.util[].avg(600)}>80 I have an alert but after 600 seconds + 7 minutes !
            Why i have 7 minutes i dont know but i look.
            • zabbix_zen
              • Jul 2009
              • 426
              Something's going wrong between your actions queue and your action dispatcher(sms, email server,..). It should take about a minute.
              Last of(most recent) value. where in the Parameter,
              num – ignored seconds
              #num – Nth value
              so .avg(600) computes the average between 600sec of your last collected data, whereas .avg(#10) would compute the average between your last 10 gathered values.
              I think you should decrease your Item's update interval, maybe you're overloading your server with a uselessly high Item's refresh rate.
              Why would you want to gather data in 10sec interval only to be alerted if a threshold of a 600sec has been crossed anyways?
              • Thib
                • Feb 2010
                • 25
                about this .. !
                this works on every of my servers, excepted one
                383:20100311:124611 Requested [system.cpu.util[,,avg1]]
                383:20100311:124611 Sending back [0.000000]
                it always stays at 0% (min, max, && average )
                • subba5678
                  • May 2010
                  • 132
                  Can you please post how to Create an Item for the same ,as because i created an item with Zabbix Active Agent and i am not getting any alert . I am using the below parameter , is this correct , if not please help me out.
                  {BLR-NOC-06:system.cpu.util[].last(0)}>10 as well as
                  {BLR-NOC-06:system.cpu.util[].last(0)}>80
                  Thanks,
                  Subbu
