What's the difference in an item vs. trigger
  • agentguerry
    • Jul 2009
    • 45
    First,
    thanks for looking. I am new to zabbix, and reading through the manual, but it doesn't really say what the difference is between an "item" and a "trigger".
    If one doesn't want to monitor say "IMAP" should i be disabling the item or trigger, or both?
    Thank you for helping me understand the differences.
  • MrKen
    • Oct 2008
    • 652
    Disable the item. If the item is disabled then the trigger can't fire anyway. Or you can disable both - up to you.
    Regarding items and triggers, see this post http://www.zabbix.com/forum/showthread.php?t=14404
    HTH
    MrKen
    • agentguerry
      • Jul 2009
      • 45
      Thank you.
      I found the wiki hidden around also, and this link explains a lot.
      http://www.zabbix.com/wiki/howto/con...nd_hosts_oh_my
