"No Data" for New host
  • vietwow
    • Nov 2009
    Hi all,
    I installed zabbix-1.6.6 from source on CentOS 5 64-bit, everything is ok
    I install & active monitor on Zabbix Server (actuallly, it's localhost) as http://www.muck.net/?p=16 guides
    To monitor your zabbix server, you can go to the Configuration Tab, and choose the “hosts” sub Tab. Select the “Zabbix Server” host, by putting a checkmark next to it. and choose the “Activate Selected” button below. Wait a minute or two, then select the “Monitoring” tab, and then the “latest data” sub tab. You should start seeing performance stats appear!
    Some graphs is already created default, so I check result in tab "screen", every graphs works very good
    And then I create a new host, use the same group "Zabbix Servers" with "Zabbix Server" host, but when I add graphs , every graphs is "No data". I don't why, I try some another cases, create new host with new group, ... but still "No data". So only first default host "Zabbix Server" works
    Anybody help me ?
    Thanx
    Regards,
  • MrKen
    • Oct 2008
    • 652
    When you created the new host, on the Host config page there is a box which says 'Connect to'. Be sure that you chose the correct one, IP or DNS.
    Also, did you link your new host with a Template?
    Otherwise, check your zabbix_server.log for errors for the new host.
    MrKen
