Zabbix and BizTalk
  • trikke
    • Aug 2007
    • 140
    Zabbix and BizTalk
    Someone willing to share their "monitoring solution" to monitor BizTalk with Zabbix?
    Greets
    Patrick
  • g.fernandez
    • Apr 2014
    Powershell scripts, JSON objects, LLD rules and performance counters
    Powershell scripts, JSON objects, LLD rules and performance counters give you control over all performance counters that you need to retrieve from you BizTalk Server.
    I know it's been a while but I hope this helps somebody.
