ZABBIX server is running = No
  • channelasian
    • Nov 2009
    • 16
    Hello there,
    i got problem with my zabbix server is not running. Please take a look at the img below.
    #! /bin/sh
    # Zabbix daemon start/stop script.
    # Written by Alexei Vladishev <[email protected]>.
    NAME=zabbix_server
    PATH=/bin:/usr/bin:/sbin:/usr/sbin:/home/zabbix/bin
    DAEMON=/usr/sbin/${NAME}
    DESC="Zabbix server daemon"
    PID=/var/tmp/$NAME.pid
    zabbix@monitor:~$ sudo /etc/init.d/zabbix-server start
    Starting Zabbix server daemon: zabbix_server
    zabbix@monitor:~$
    I still cant see the status of my zabbix server up.
    Please help...!!!
  • zabbix_zen
    • Jul 2009
    • 426
    What does zabbix_server.log complain about?
    • channelasian
      • Nov 2009
      • 16
      how to see the zabbix_server.log?
      • jthakrar
        • Oct 2009
        • 43
        You can check two things -
        1. Check the "PID" file given by ->>> PID=/var/tmp/$NAME.pid
        See if it contains the process-id of your Zabbix server and see if the process is running
        2. Check the Zabbix server log file.
        The location is given by the zabbix-server configuration file in /etc/zabbix
        (assuming you are using the standard location)
        Those two should be able to give you some insight into what's happening and help you troubleshoot.
        • zabbix_zen
          • Jul 2009
          • 426
          Assuming your distro has locate installed you can search for further files you don't know the whereabouts using
          locate file_you_want_to_search
          don't forget to run first
          updatedb
          • channelasian
            • Nov 2009
            • 16
            below is my zabbix_server.log
            1507:20091127:032918 Starting zabbix_server. ZABBIX 1.6.7 (revision 8252).
              1507:20091127:032918 **** Enabled features ****
              1507:20091127:032918 SNMP monitoring:       YES
              1507:20091127:032918 WEB monitoring:        YES
              1507:20091127:032918 Jabber notifications:   NO
              1507:20091127:032918 ODBC:                   NO
              1507:20091127:032918 IPv6 support:           NO
              1507:20091127:032918 **************************
              1507:20091127:032918 [Z3001] Connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
              1724:20091127:033431 Starting zabbix_server. ZABBIX 1.6.7 (revision 8252).
              1724:20091127:033431 **** Enabled features ****
              1724:20091127:033431 SNMP monitoring:       YES
              1724:20091127:033431 WEB monitoring:        YES
              1724:20091127:033431 Jabber notifications:   NO
              1724:20091127:033431 ODBC:                   NO
              1724:20091127:033431 IPv6 support:           NO
              1724:20091127:033431 **************************
              1724:20091127:033431 [Z3001] Connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
              1733:20091127:033447 Starting zabbix_server. ZABBIX 1.6.7 (revision 8252).
              1733:20091127:033447 **** Enabled features ****
              1733:20091127:033447 SNMP monitoring:       YES
              1733:20091127:033447 WEB monitoring:        YES
              1733:20091127:033447 Jabber notifications:   NO
              1733:20091127:033447 ODBC:                   NO
              1733:20091127:033447 IPv6 support:           NO
              1733:20091127:033447 **************************
              1733:20091127:033447 [Z3001] Connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
            how to fix this problem?
            • MrKen
              • Oct 2008
              • 652
              channelasian,
              You're doing a lot of cross-posting!!
              This appears to be fixed in your post here http://www.zabbix.com/forum/showthre...t=11742&page=2
              quote: "It works fine now. Thanks a lot."
              • channelasian
                • Nov 2009
                • 16
                Originally posted by MrKen
                channelasian,
                I am sorry. because i am trying to find and fix the problem which i am facing.
                Thanks alot for your help.
                • zabbix_zen
                  • Jul 2009
                  • 426
                  So, is it solved or what?
                  I think this is pretty self explanatory.
                  check what you have in field DBPassword in your zabbix_server.conf and if it's your current DB password
                  • channelasian
                    • Nov 2009
                    • 16
                    Yeah, it solved now.
                    Thanks alot for all your help.
                    • yas
                      • Apr 2010
                      • 25
                      i have same problem plz help me .... my os ubuntu 9.10 zabbix ver 1.8.1
                      • yas
                        • Apr 2010
                        • 25
                        zabbix server is running = No
                        hello there any body help me i have same problem my zabbix server not running
                        • MrKen
                          • Oct 2008
                          • 652
                          What does zabbix_server.log say?
                          You might find the log in /tmp/ or in /var/log/ or .....
                          • jthakrar
                            • Oct 2009
                            • 43
                            How did you determine that the zabbix server is not running - the GUI frontend or some other way?
                            Here are three basic things that you can check to start with -
                            1) Check the server log (see MrKen's reply)
                            2) Check for the server process (you will find the process id in a "tmp" or "temp" file somewhere, based on your configuration
                            3) Check for the server port (default of 10051)
                            • yas
                              • Apr 2010
                              • 25
                              #15
                              how to add host to zabbix
                              my zabbix server does not able to add the hosts . how i can manage my users on zabbix and define the ip addresses on the zabbix server and configure the monitoring network inbond - outbond....etc
