Hey All,
I needed to roll some RPM's for work so I figured I would make them available to you as well. The are located in a yum repository and are all signed. I have also included all dependencies that are not in OS/Updates.
If you know what you are doing the repo is available at: http://mirrors.netdna.com/NetDNA/centos/4/i386
and
(Sorry I wont have access to my 64bit build box till monday, however the src.rpm is there and should be good to go).
For those of you with CentOS4 still I have included the repackaged curl that will auto update when you install Zabbix to make it easier for you
Hopefully I will have the new alpha up as well tomorrow... we will see though
Let me know if you have any issues with it.
and
