Solaris 10 sparc compile errors
  • estrawser
    • Dec 2009
    • 9
    I'm supposed to test out Zabbix to see if we'll want to use it as a monitoring solution. I'm running into all sorts of problems, though.
    checking for curl-config... /usr/local/bin/curl-config
    checking for the version of libcurl... 7.19.6
    checking for libcurl >= version 7.13.1... yes
    checking for main in -lcurl... no
    configure: error: Not found libcurl library
    Is the latest one. /usr/local/bin/curl-config is there. I can only compile if I use --with-libcurl=no, but even if I do that, I can't get to ~zabbix on the server. I did build it without libcurl, but can't access it, at all, even after starting the server.
    Is it supposed to be this difficult under solaris?
    Edit: MOre info:
    ./configure --enable-server --with-net-snmp --with-pgsql --with-libcurl=/usr/local/bin/curl-config CFLAGS="-I/usr/local/include"
    echo $PATH
    /usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/usr/sfw/bin:/usr/ccs/bin:/usr/openwin/bin:/usr/ucb:/home/strawser/scripts:/opt/coolstack/mysql_32bit/bin:/opt/coolstack/mysql_32bit/bin:/usr/ccs/bin:/bin:/etc:/usr/ccs/bin:/usr/openwin/bin:/opt/bin:/usr/local/bin:/usr/sfw/bin
    From config.log:
    configure:9905: checking for curl-config
    configure:9936: result: /usr/local/bin/curl-config
    configure:9947: checking for the version of libcurl
    configure:9954: result: 7.19.6
    configure:9961: checking for libcurl >= version 7.13.1
    configure:9974: result: yes
    configure:10085: checking for main in -lcurl
    configure:10114: gcc -o conftest -I/usr/local/include -I/usr/include/pgsql -I/usr/local/include -L/usr/local/lib -lcurl -L/usr/local/lib -L/usr/lib -L/usr/openwin/lib -L/usr/local/ssl/lib -L/usr/local/BerkeleyDB.4.2/lib -lidn -lssh2 -lssl -lcrypto -lsocket -lnsl -lz conftest.c -lcurl -lkvm -lm -lresolv -lnsl -lkstat -lsocket >&5
    ld: fatal: library -lidn: not found
    ld: fatal: library -lssh2: not found
    ld: fatal: File processing errors. No output written to conftest
    collect2: ld returned 1 exit status
    configure:10120: $? = 1
    configure: failed program was:
    | /* confdefs.h. */
    | #define PACKAGE_NAME ""
    | #define PACKAGE_TARNAME ""
    | #define PACKAGE_VERSION ""
    | #define PACKAGE_STRING ""
    | #define PACKAGE_BUGREPORT ""
    | #define PACKAGE "zabbix"
    | #define VERSION "1.6.7"
    | #define STDC_HEADERS 1
    | #define HAVE_SYS_TYPES_H 1
    | #define HAVE_SYS_STAT_H 1
    | #define HAVE_STDLIB_H 1
    | #define HAVE_STRING_H 1
    | #define HAVE_MEMORY_H 1
    | #define HAVE_STRINGS_H 1
    | #define HAVE_INTTYPES_H 1
    | #define HAVE_STDINT_H 1
    | #define HAVE_UNISTD_H 1
    | #define HAVE_STDIO_H 1
    | #define HAVE_NETDB_H 1
    | #define HAVE_SIGNAL_H 1
    | #define HAVE_SYSLOG_H 1
    | #define HAVE_TIME_H 1
    | #define HAVE_ERRNO_H 1
    | #define HAVE_NETINET_IN_H 1
    | #define HAVE_MATH_H 1
    | #define HAVE_SYS_SOCKET_H 1
    | #define HAVE_DIRENT_H 1
    | #define HAVE_CTYPE_H 1
    | #define HAVE_FCNTL_H 1
    | #define HAVE_SYS_PARAM_H 1
    | #define HAVE_SYS_MOUNT_H 1
    | #define HAVE_ARPA_INET_H 1
    | #define HAVE_SYS_VFS_H 1
    | #define HAVE_SYS_SYSINFO_H 1
    | #define HAVE_SYS_STATVFS_H 1
    | #define HAVE_SYS_LOADAVG_H 1
    | #define HAVE_SYS_SWAP_H 1
    | #define HAVE_SYS_VMMETER_H 1
    | #define HAVE_SYS_TIME_H 1
    | #define HAVE_KSTAT_H 1
    | #define HAVE_SYS_SYSCALL_H 1
    | #define HAVE_SYS_SYSMACROS_H 1
    | #define HAVE_SYS_PROCFS_H 1
    | #define HAVE_PWD_H 1
    | #define HAVE_SYS_PROC_H 1
    | #define HAVE_SYS_VAR_H 1
    | #define HAVE_RESOLV_H 1
    | #define HAVE_ARPA_NAMESER_H 1
    | #define HAVE_ASSERT_H 1
    | #define HAVE_NLIST_H 1
    | #define HAVE_NET_IF_H 1
    | #define HAVE_KVM_H 1
    | #define HAVE_GETOPT_H 1
    | #define HAVE_SYS_RESOURCE_H 1
    | #define HAVE_PTHREAD_H 1
    | #define HAVE_SYS_WAIT_H 1
    | #define HAVE_REGEX_H 1
    | #define HAVE_STDARG_H 1
    | #define HAVE_SYS_SEM_H 1
    | #define HAVE_SYS_IPC_H 1
    | #define HAVE_SYS_SHM_H 1
    | #define HAVE_SYS_TIMEB_H 1
    | #define HAVE_LBER_H 1
    | #define HAVE_SYS_FILE_H 1
    | #define HAVE_GRP_H 1
    | #define HAVE_SYS_USER_H 1
    | #define HAVE_LIBM 1
    | #define HAVE_LIBKVM 1
    | #define HAVE_RES_QUERY 1
    | #define HAVE_PROC 1
    | #define HAVE_PROC_0_PSINFO 1
    | #define HAVE_SYS_RESOURCE_SETPRIORITY 1
    | #define HAVE_UNISTD_SYSCONF 1
    | #define HAVE___VA_COPY 1
    | #define HAVE_SYS_SWAP_SWAPTABLE 1
    | #define HAVE_FUNCTION_INITGROUPS 1
    | #define HAVE_FUNCTION_SETEUID 1
    | #define HAVE___VA_ARGS__ 1
    | #define RETSIGTYPE void
    | #define HAVE_GETLOADAVG 1
    | #define HAVE_SOCKET 1
    | #define HAVE_STRTOD 1
    | #define HAVE_SNPRINTF 1
    | #define HAVE_VSNPRINTF 1
    | #define HAVE_HSTRERROR 1
    | #define HAVE_ATOLL 1
    | #define HAVE_GETOPT_LONG 1
    | #define HAVE_POSTGRESQL 1
    | #define HAVE_FUNCTION_PQSERVERVERSION 1
    | /* end confdefs.h. */
    | int
    | main ()
    | return main ();
    | return 0;
    configure:10138: result: no
    configure:10146: error: Not found libcurl library
  • untergeek
    • Jun 2009
    • 512
    With Solaris 10 I have similar problems. I find that I have to pre-pend my configure statement with a few extras. Your statement seems to post-pend (for some reason it seemed to matter. Here's what I had to do to get mine to compile:
    CC=/usr/bin/cc CFLAGS="-I/opt/sfw/include" LDFLAGS="-L/opt/oracle/product/10.2.0.1/lib32 -R/opt/oracle/product/10.2.0.1/lib32" ./configure --with-net-snmp=/usr/local/bin/net-snmp-config --with-libcurl=/opt/sfw/bin/curl-config --with-oracle=/usr/local --enable-server --enable-proxy --enable-agent
    My lib-curl was in /opt/sfw/include as it came with the Solaris extras CD.
    You might try pre-pending the CFLAGS rather than post-pending it.
    • Tenzer
      • Nov 2007
      • 316
      libcurl depends on libssh2 and libidn, which you don't seem to have:
      You could try the following command to make sure that you have the required libraries: ldd `which curl`
      Oh, and libssh2 and libidn can be found at www.sunfreeware.com, if you don't know already.
      • estrawser
        • Dec 2009
        • 9
        Thanks! I appreciate the help. I didn't realize I had to install those two packages.
        Now . . . how do I get it started. HTTP://hostip gives me the default page. Is it running on a different port than 80, or something?
        • Tenzer
          • Nov 2007
          • 316
          Zabbix does not run it's own webserver, you will have to move the frontend PHP files to the webservers document root.
          • estrawser
            • Dec 2009
            • 9
            Thanks a billion. I'm coming closer by the day.
            PHP version: 5.2.6 Ok
            PHP Memory limit: 64M Ok
            PHP post max size: 8M Ok
            PHP max execution time: 30 sec Fail
            PHP Databases support: MySQL Ok
            PHP BC math support: no Fail
            PHP Sockets support no Fail
            GD Version: No Fail
            Image formats: No Fail
            PHP Timezone: n/a Fail
            Does anyone know how to fix the PHP max execution time, or where to find the missing parts for the tests I'm failing?
            Edit:
            I've uncommented :
            extension=bcmath.so
            extension=sockets.so
            In /opt/coolstack/php5/lib/php.ini, but it didn't fix those two problems. There was no timezone statement in there.
            • untergeek
              • Jun 2009
              • 512
              php.ini, wherever yours is.
              Mine's in /usr/local/lib, with entries like these:
              memory_limit = 128M ; Maximum amount of memory a script may default_socket_timeout = 1800
              date.timezone = "America/Austin"
              max_execution_time = 300
              It seems you also have to recompile your PHP with BC Math, GD (with PNG support) and PHP Sockets.
              Good luck!
              • estrawser
                • Dec 2009
                • 9
                Mine's in /opt/coolstack/php5/lib/php.ini, but when I added those lines for date.timezon and max_execution_time it didn't fix those two errors.
                • untergeek
                  • Jun 2009
                  • 512
                  America/Chicago is a better choice for Central time.
                  Did you restart Apache after making the change? It isn't automatic.
                  • estrawser
                    • Dec 2009
                    • 9
                    Oh, WOW. Thanks! Much, much better.
                    PHP max execution time: 300 sec Ok
                    PHP BC math support: yes Ok
                    PHP Sockets support yes Ok
                    GD Version: No Fail
                    PHP Timezone: America/Austin Ok
                    I installed GD from sunfreeware.com, but I guess it's missing from a path statement or something. And I don't get any pop-up help for "Image formats".
                    • untergeek
                      • Jun 2009
                      • 512
                      There may be dependent packages. You have GD, but do you have the PNG portion? Do you have PHP-GD?
                      • estrawser
                        • Dec 2009
                        • 9
                        I just ran: /opt/csw/bin/pkgutil --install CSWphp5gd
                        Then restarted apache. Still no graphics support.
                        GD Version: No Fail
                        • estrawser
                          • Dec 2009
                          • 9
                          Sweet! I had to uncomment
                          extension=gd.so
                          In php.ini and I'm now past the prereq check. Thanks a million!
                          • estrawser
                            • Dec 2009
                            • 9
                            Wouldn't it be hilarious if I finally got through the installation and I couldn't log in because I don't remember setting an admin username and password? I sure hope so, because that's what happened.
                            At the risk of sounding like a total buffoon, does anyone know how to set a username and password once the install is complete?
                            Edit: Never mind. I found the default login/pass in the docs. Thanks again, everyone!
                            • Tenzer
                              • Nov 2007
                              • 316
                              #15
                              Page 63 in the manual states:
                              ZABBIX frontend is ready! Default user name is ‘Admin’, password
                              'zabbix'.
