How To Calculate Item based on two others
  • CHOUETTE38
    • Sep 2009
    • 9
    Through SNMP, I retrieve two value for printer consumable like toner.
    Full capacity
    Capacity available.
    So the Capacity available/Full capacity give the % available.
    If I have no problem to define a trigger to have an alert in case of low capacity, I would to show the % available on a screen.
    How to do that ?
    Is it possible to define Item Calculated based on other Items ?
    Other Idea ?
    Thanks in advance for your answer
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It is very likely that this functionality will be supported in Zabbix 2.0.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
