trigger function count()
  • MartinJanda
    • Oct 2009
    • 27
    I'm making trigger for SNMP trap. I need to create a trigger that will appear on the main page when it comes trap value 1, and it will remain displayed for 10 minutes. Then canceled.
    I try function count(600) = 1 and count(600,1) = 1 and count(600,'1') = 1. Trigger starts, but doesn't end after ten minutes.
    I would like solve this problem. Unfortunately, device sends only the trap 1 and never 0 as it was ok.
    Do you have a solution for this problem? I have Zabbix 1.6.6
    Thank advance
  • MartinJanda
    • Oct 2009
    • 27
    I have tried to funciton avg(60) and the same result.
    Why are these functions ignore the parameter in seconds?
    Is it fixed Zabbix 1.8?
    Thank you for information.
    • MartinJanda
      • Oct 2009
      • 27
      Give me advice please. This is the last problem before we put into full operation Zabbix replacement for Nagios. I would hate to find alternative solutions for such a small thing, especially when other Zabbix works really well.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Normally triggers are recalculated ONLY on receipt of a new value. Think about it, if you have no value count() will never be recalculated, so you will never get a trigger in status OK.
        In order to force triggers recalculate periodically, you should also use time-related functions, such as nodata(), time(), date(), etc. So, a combination of count() with nodata() should make the trick.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • MartinJanda
          • Oct 2009
          • 27
          Amazing. With a nodata function and not equal operator (#) it really works.
          Thank you very much.
          I have an idea for you. Lots of smaller companies around does not use commercial support, but if you should donate through paypal, would some users help a small amount for development.
