Zabbix 1.8 - Display bandwidth on Maps
  • laakness
    • Oct 2009
    • 20
    I was taking a look at the new features of 1.8 and I was really interested in being able to display the bandwidth on the links between sites.
    I'd imagine I have to add something in the Link text/description/title that would pull data from one of my already monitored SNMP items.
    My question is how do I go about adding this information correctly?
  • kangaroos
    • Jul 2009
    same question, i have found how to put a test on a link but how can we ut the bandwitch ?
    I think it's only an item but what is the syntax ?
    • kangaroos
      • Jul 2009
      OK, i have found.
      On link label you put your text and variables. The variables have the same syntax of triggers.
      Exemple, my host name is : FRDE_E06-0_S001
      My item is : ifInOctets.10648
      and you want le last value so : last(0)
      Put in your link label :
      Input : {FRDE_E06-0_S001:ifInOctets.10648.last(0)}
      Output : {FRDE_E06-0_S001:ifOutOctets.10648.last(0)}
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Note that you may also use other functions, for example, average for 5 minutes:
        Input : {FRDE_E06-0_S001:ifInOctets.10648.avg(300)}
        Output : {FRDE_E06-0_S001:ifOutOctets.10648.avg(300)}
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • laakness
          • Oct 2009
          • 20
          Works great, thanks.
          • tenhlf
            • Feb 2010
            • 9
            Output : {H3C 3100 5F:ifOutOctets.4227722.avg(300)}
            Input : {H3C 3100 5F:ifInOctets.4227722.avg(300)}
            This is my link label.
            Result
            Output : 56kB
            Input : ???
            ifOutOctets can work well. all ifInOctets result is ???
            my vseion is 1.8.1 freebsd mysql
            why?Thanks.
            • richlv
              • Oct 2005
              • 3112
              check whether that item is really configured with such a key and that it is receiving data - most likely it isn't
              • laakness
                • Oct 2009
                • 20
                That is what I have found as well. Anytime I have had the ??? it was because it was a typo or a missing item that has no values.
                • tenhlf
                  • Feb 2010
                  • 9
                  The key is receiving data ,I also use ifInOctects.4227722 and ifOutOctets.4227722 the value of the image generated Traffic。
                  • tenhlf
                    • Feb 2010
                    • 9
                    Input : {H3C 3100 5F:ifInOctects.4227722.avg(300)}
                    I finally succeeded,thanks!
                    • prina72
                      • Sep 2012
                      Zabbix 2.0.1 - Display bandwidth on Maps
                      Hi All,
                      I need to display bandwidth on zabbix 2.0.1, I have followed the instructions on the below thread but it doesn't work.
                      The key is generated by discovery, despite I found the right Octets value it doesn't work.
                      Did it change something on 2.0.1 version?
                      Please let me know.
