Need help with group/host table screen/dashboard
  • bigmac
    • Nov 2009
    • 21
    I need to setup the first screen of zabbix to show network map and table containing host groups with information of quantity of hosts in group, active hosts, number of different classes of problems. When clicked, host group name should expand and show all hosts contained with more detailed status.
    I am unable to find any Zabbix Monitoring screens showing these. Is it possible to manually edit built-in Monitoring screens without redesigning the source code?
    tia
  • richlv
    • Oct 2005
    • 3112
    configuration -> screens, although i'm not aware of a screen element that would provide hostgroup drilldown that you describe
    • bigmac
      • Nov 2009
      • 21
      Well, multi-level maps provide sort of drilldown, but i do not know, how to edit the information shown near host/submap, it happens to be fixed. (I hope Zabbix would become more flexible and user-configurable in each next version. At least, do not set unsymmetrical restrictions).
      Where are System Status, Dashboard and other layouts defined? I think it would be much easier to adapt some existing layout to fit my needs.
      Thanks,
      Paul
