Hi, guys.
Several weeks agog I've posted, that zabbix 1.7.1 doesn't work on my FreeBSD installation.
So I've installed zabbix 1.8 from ports on FreeBSD 7.2 and have the same stuff
Any ideas how to fix this?
27642:20091214:155603.597 Starting zabbix_server. Zabbix 1.8 (revision 8565).
27642:20091214:155603.597 **** Enabled features ****
27642:20091214:155603.597 SNMP monitoring: YES
27642:20091214:155603.597 IPMI monitoring: NO
27642:20091214:155603.598 WEB monitoring: YES
27642:20091214:155603.598 Jabber notifications: YES
27642:20091214:155603.598 ODBC: NO
27642:20091214:155603.598 SSH2 support: NO
27642:20091214:155603.598 IPv6 support: YES
27642:20091214:155603.598 **************************
27642:20091214:155603.598 Connect to the database
27642:20091214:155603.605 Query [txnlev:0] [SET NAMES utf8]
27642:20091214:155603.605 Query [txnlev:0] [SET CHARACTER SET utf8]
27642:20091214:155603.605 Query [txnlev:0] [select refresh_unsupported from config where 1=1 and configid between 000000000000000 and 099999999999999]
27642:20091214:155603.606 Query [txnlev:0] [select masterid from nodes where nodeid=0]
27642:20091214:155603.607 In DBupdate_triggers_after_restart()
27642:20091214:155603.607 Query [txnlev:1] [begin;]
27642:20091214:155603.607 Query [txnlev:1] [select distinct t.triggerid,t.expression,t.description,t.status,t.priority,t.value,t.url,t.comments from hosts h,items i,triggers t,functions f where h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid and h.status in (0) and i.status in (0) and t.status in (0) and i.type not in (2) and i.key_ not in ('status','zabbix[log]')]
27642:20091214:155603.609 Query [txnlev:1] [commit;]
27642:20091214:155603.609 End of DBupdate_triggers_after_restart()
27642:20091214:155603.610 In init_database_cache() size:29361092
27642:20091214:155603.610 Can't allocate shared memory of size 29361092 [Cannot allocate memory]
27642:20091214:155603.610 Can't allocate shared memory for database cache.
