I'm playing around with the web gui for 1.8 and I'm having an issue changing simple trigger values. For example, if I want to change the default cpu load trigger from N>5 to N>15. I go to Configuration-->Hosts-->Triggers and find the line for "Processor Load is Too High" and click. Next to the Expression line there is a SELECT button. I click that and it pops open a small window. In that new window I change the value of N from "5" to "15" and click INSERT. This adds the new expression to the end of the old expression. But what the hell....I click SAVE. That returns me to the screen showing all triggers and I note that the trigger I just changed hasn't changed at all.
I'm clearly not doing something correctly. Could someone nudge me in the proper direction? Do I need to create an entirely new trigger rather than attempt to edit an existing one?
