I have a strange problem, i have 3 nodes 1 master and 2 client nodes.
One client node communicates normal with the master and back aging
But the new node dos this strange thing with his communication.
It sends his history data tot the master and he receives it and the last communication is “node 3: sending configuration changes to master node 1 for node 3 datalen 4099036”
I expect that node 3 is waiting for re-communication because he stops with al communication.(I have waited for over one hour)
When I stop the zabbix services on the master, I get un error on the client node “node 3: Error while receiving answer from node[1] error: ZBX_TCP_READ() failed [Connection reset by peer]” and a lot of “unable to connect to node [1] errors”.
After the errors the com. from node 3 starts aging with sending the history until there’s a configuration communication
The communication is over a network without firewall or any other obstruction
Master = 1.6.6
Both nodes are = 1.6.7
All are ubuntu master and node 2 are 9.04 and node 3 is 9.10
I hope someone can help me,
Greets,
Dominic
Master = 1.6.6
Greets,
Dominic
sadly.
