Item not collecting data, cant figure out why
  • Govenor
    • Dec 2009
    • 11
    Ok i have an item that is looking at a log for successes, and it works just fine. I am trying to duplicate that to another log on the same host to test it. So i have two items and two triggers that almost identical, except they point to different log files, that's it.
    The problem is the only one item (the non-test one) works just fine, but under monitoring > Latest data, only that one item is recording data.
    I created a .txt file for it to look at it, made sure the name was right, even case sensitive wise, the zabbix agent has full control to the .txt file. For some reason it just wont record any data, and i have deleted it several times and tried from scratch all over again with the same results every time.
    I have exhausted my mental resources and need some fresh brains to help me out!
    Any help is appreciative!
  • richlv
    • Oct 2005
    • 3112
    is item type set to zabbix active agent ? is value type set to log ?
    basically, show the item config.
    • Govenor
      • Dec 2009
      • 11
      here it is
      log[Root\Errorlog.txt,ERROR|FAILED|ZERO]
      it is set to log, and it set to Zabbix Agent (Active)
      • richlv
        • Oct 2005
        • 3112
        that's item key only, not full config - but path looks weird. are you sure it is correct ? which platform ?
        • asa1985
          • Sep 2010
          • 16
          I have the same problem...
          I need HELP!!!
