Linux item creation help!
  • Govenor
    • Dec 2009
    • 11
    I know very little about Linux and I am trying to monitor a specific process that is running a dozen or two different Linux machines. I am planning on modifying the Linux template to accomodate this need. However I am not sure what key i would use to accomplish this goal.
    Would I use proc.num[processname] ? then for the trigger put last(0)=0 if the process stopps running? Would that work?
    Thanks!
  • ericgearhart
    • Jan 2009
    • 115
    Basically, yes
    You can see an example from the Linux template (in Zabbix 1.8 anyway... not sure about older versions)
    Item name - Number of running processes sshd
    Key - proc.num[sshd]
    And there's a trigger bound to that item, named "Sshd is not running on {HOSTNAME}"
    The expression for it is:
    {Template_Linux:proc.num[sshd].last(0)}<1
    But doing "=0" on the end would have the same effect....
