Not Polling After 1.6.6=>1.8
  • gpmidi
    • Aug 2009
    • 62
    I upgraded my Zabbix install from 1.6.6 to 1.8. After the upgrade Zabbix no longer polled any of the items on the local host entry. It's only monitoring its self so I don't know if a local problem only. The agent and server log files do not have anything interesting when set to log level 3. Lots of noise on level 4 but nothing of interest that I've seen.
  • tekemp
    • Sep 2009
    I am having this very same issue after upgrading to 1.8, any solutions?
    • gpmidi
      • Aug 2009
      • 62
      Groups
      Is the host(s) in question contained in any groups? If not try adding it to a group. If that doesn't work IDK. I ended up just re-creating the hosts because it was a non-production system.
      • tekemp
        • Sep 2009
        Thanks for the quick response, bummer though because they are indeed members of groups. I hope I don't have to recreate all of these hosts i have over 50!
        • gpmidi
          • Aug 2009
          • 62
          Irc
          Try in IRC. Richv is usually around and is very helpful.
