activate a trigger by command line
  • jcdvz
    • Jan 2010
    HI,
    is it possible to activate or deactivate a trigger by command line ?
    (and how)
    Thanks for your help
  • fatiha
    • Nov 2007
    • 78
    You can execute an update SQL command.
    • jcdvz
      • Jan 2010
      Thanks Fatiha,
      I thought somethings more simple. I a bit afraid to make change directly in zabbix database.
      • alixen
        • Apr 2006
        • 474
        May be I don't understand what you want to do since triggers depend on item values.
        However, if your trigger is associated to an item of type "Zabbix trapper", you can change item value with zabbix_sender command line utility.
        Regards,
        Alixen
        http://www.alixen.fr/zabbix.html
        • jcdvz
          • Jan 2010
          Thanks for your attention,
          I just don't want to receive alert between 2 hours during a bakcup.
          I would like, that the backup script stop the monitoring at the beginning and restart it at the end of backup.
          ps:sorry for my English mistakes
          • exkg
            • Mar 2007
            • 718
            I think 'time' function for trigger can help you.
            []s,
            Luciano
            Luciano Alves
            www.zabbix.com
            Brazil | México | Argentina | Colômbia | Chile
            Zabbix Performance Tuning
            • jcdvz
              • Jan 2010
              thanks luciano,
              I'm going to use this solution if it isn't possible to deactivate a trigger by simple command line.
              But if someone know another solution, he can propose it.
              Thanks everybody for your help
              • tighep
                • Dec 2007
                • 124
                Why not create a zabbix trapper item, and have the backup script update the item when it starts and finishes. This item has an informational trigger, that your original trigger depends on. That way you won't get the alerts during the backup, and you'll actually know when that window was on a daily basis.
                • jcdvz
                  • Jan 2010
                  thanks tighed,
                  this is exactly what i want to do.
                  I don't know why i haven't understood when Alixen has proposed to me to use zabbix trapper item and zabbix_sender command.
                  and one more time many thanks everybody
                  • jcdvz
                    • Jan 2010
                    sorry : thanks tighep and not tighed
                    • exkg
                      • Mar 2007
                      • 718
                      And about 'Maintenance Periods' (ZBX-1.8) ?
                      You can schedule to a host or host groups and choose to collect data or not during this period.
                      []s,
                      Luciano
                      Luciano Alves
                      www.zabbix.com
                      • jcdvz
                        • Jan 2010
                        we are in zabbix 1.4.1 and it seems me that it doesn't exist maintenance period in this version.
                        But in our case zabbix_sender + item zabbix_trapper is a good solution
                        RGDS
                        JCDVZ
