Zabbix won't use secondary DNS Server
  • ewan
    • Apr 2009
    Hi All,
    We are using zabbix 1.6.6 on RHEL 5.3 and have about 200 hosts set up which are a mix of linux, unix, windows and snmp devices. The zabbix server has 2 network interfaces with the second interface configured as the SourceIP and ListenIP in zabbix_server.conf.
    On the most part zabbix is set to connect to the DNS name of each host rather than the IP address as many hosts use dhcp.
    We have 2 windows DNS servers, both listed in resolve.conf on the zabbix server.
    When the primary DNS server is down (say for maintenance) zabbix loses connection to all the hosts it is using DNS to connect to, even though I can still ping each dns name from the server's command line (using the secondary DNS). It seems zabbix itself is unable to use a secondary DNS server for name resolution.
    Am I missing something in a configuration file somewhere?
    Regards,
    Ewan
  • krimson
    • Sep 2008
    • 49
    Name resolution is handled by the OS, not by Zabbix.
    Annoyingly when Windows DNS servers are down they sometimes still seem 'up and running' causing the OS not to fail over to the second DNS server.
    Either tell Zabbix to connect to the IP instead of DNS name (which requires you to fill in all the IP's ...) or get rid of the Windows DNS servers
    • exkg
      • Mar 2007
      • 718
      A good choice is to use a 'cache DNS' in ZABBIX Server ....
      []s,
      Luciano
      Luciano Alves
      www.zabbix.com
      Brazil | México | Argentina | Colômbia | Chile
      Zabbix Performance Tuning
      • nelsonab
        • Sep 2006
        • 1233
        In one environment windows DNS servers proved to be so flakey we added slave bind instance on the zabbix server.
        RHCE, author of zbxapi
        • ewan
          • Apr 2009
          Yeah, thought it was more likely a problem with Windows than Zabbix
          Thanks for the ideas guys. So you reckon installing something like dnsmasq on the zabbix server and pointing it at our windows dns servers should "smooth" out my DNS experience?
          Thanks again
          Ewan
          • nelsonab
            • Sep 2006
            • 1233
            I can't speak with regards to DNS Masq very much except to say that some people have had issues with it not caching properly or for too long. My suggestion is to setup a slave DNS server on your Zabbix box and have it resolve from there.
            Thanks again
            Ewan
            • danrog
              • Sep 2009
              • 164
              This is what we use on our Linux hosts
              domain blah.com
              nameserver 10.10.10.5
              nameserver 10.10.10.6
              options timeout:3 attempts:2 rotate
              This last line is what fixed the use of secondary dns servers for us.
              • nelsonab
                • Sep 2006
                • 1233
                domain blah.com
                Cool! Didn't know about those options, learn something new every day!
                • danrog
                  • Sep 2009
                  • 164
                  There are actually a few different settings available.
                  http://linux.die.net/man/5/resolv.conf
                  On some parts of our global network (especially where we have hot standy servers) we use sortlist and search options (to change default search order) so we can force the DNS responses we want.
                  I should also note, all internal DNS is run on Windows (because of AD and the fact that 90% of our clients are Windows based) and these options helped us overcome DNS query failures during AD server maintenance without problems.
                  • ewan
                    • Apr 2009
                    danrog,
                    Thanks very much for that - I'll give those settings a shot.
                    Cheers guys,
                    Ewan
                    • vorGroup
                      • Apr 2014
                      I beg to differ....
                      Perhaps it's SUPPOSED to just use the O/S DNS -- BUT...
                      I commented out the secondary DNS to be sure.
                      With only ONE DNS server, which works perfectly fine, and the console is ALWAYS able to resolve hostnames, every single one of my websites is showing down with the reason of inability to resolve hostname.
                      But a ping, and nslookup from the command-line of zabbix_server host always resolves the hostname perfectly.
                      If there was not a secondary problem related to Zabbix, this behavior could not happen.
